Hi guys, ive got a problem with my system which I bought from ocuk.
My machines spec is as follows:
Shuttle XPC SD31P Aluminium Barebones System - Intel P4
Intel Pentium 4 805 Dual Core
Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM
Patriot Signature 1GB (2x512MB) PC5300 667MHz DDR2 Dual Channel Kit
The problem I have is that when I turn the pc on, it will sometimes boot to windows, then after a couple of mins the machine will just lock up, sometimes it reboots and freezes on the bios screen, and a few times it has comes up with the windows Stop 0x0000007A error
Whats weird is that, if I try to reboot it straight away it will just freeze on the bios screen, but if I unplug it, leave it for a few hours, then return it will allow me to get to window for a min or so, then go into this cycle again.
So far I have, run chkhd (all fine), reseated the ram (no problems). Formatted and reinstalled windows more times than I can count, run memtest (ran for 25hrs got ****** off and cancelled it to format again),
Also weird is the fact that ive installed windows so many times on a fresh hdd, sometimes it goes on, sometimes it doesn’t, but the times it does go on, it will install, then crash again with in 5mins or finalizing setup.
Id like to test the ram in a different machine, but I don’t have another one which takes the same type.
