I've purchased an immersion heater cylinder tank which has a seperate smaller tank on top to hold the cold water. I'm planning on fitting it up this weekend, but i've been told i need an extra cold water tank above this tank to increase the pressure otherwise the cold mains water from the mixer taps will push the hot water back up meaning no hot water at the taps. Is this true? Do i need an extra large cold water tank, and does it have to be mounted above the small cold water tank attached to the immersion tank?
