I've been running it all at stock for a few weeks without a hitch now so decided it was time to try some overclocking. I had a good read around about what I might expect to get from the CPU and expected 4.8-5GHz with a vcore around 1.35v. First I tried the "easy" option using the Gigabyte EasyTune application (based on past experience of my Asus Z97 Pro Gamer which the Asus AI suite was lovely on). Needless to say this was not a good place to start, the software prompted for a restart, came back up, counted down from 30 then froze, nothing, had to hard reset to get it back.
So I thought I'd find me some guide on doing it all from the bios and found Gigabyte have published their own guide for the Z390 boards and this cpu, win! https://www.gigabyte.com/FileUpload/Global/multimedia/2/file/525/946.pdf
So I followed this guide to the letter, trying for 4.8GHz to start as that seemed reasonable, but to no avail. So yesterday I started at the bottom and worked my way up, I could only get my system to boot at 4.3GHz with vcore in auto so @ 1.2V. Anything higher than 4.3GHz wouldn't POST even at 1.4V. All using the XMP profile for the RAM.
As far as I can see 4.3 isn't really an overclock as the Intel Turbo Boost runs up to that as standard.
Any hints and tips would be much appreciated as I'm currently really disappointed with this board and I'm wondering if it's faulty or I'm just being an idiot?!
Systems spec in sig.
