Porsche Motorsport Light Base 900 Build
Any rivets to remove or was it all screwed? I remember drilling my 1000D to bits shortly after it arrived lol.
Looking nice, if it’s lots of fans don’t be scared to wire them together to reduce connectors. It’s a bit of a job but you can use any suitable 4 pin connector to join to a single PWM out and wire them in stacks. Removing the label on the rear and soldering new wires might be possible and most likely you will want some discs to cover it like aluminium or steel discs get them coated same red for example?
