Caporegime
- 9 Nov 2009
- Planet Earth
Come on AMD release the new cards already - the graphics card section is going to implode at the boredom, LOL.
Which isn't fact either as I said two 290's are cheaper, you could also get two 970's around that £530.
Unless by fact you mean in your own specified situation.
I'm talking single card obviously.
Still multi GPU so it's not fact.
I think you meant, in my opinion.
Very well may be their opinion but it still isn't fact.
Weren't you having trouble with one of your cores downclocking in GTA V?
Then show me the alternative that offers all of the above for £530.
As for gta, one of the advanced options was causing the issue, with it off the cores stay at 1018.
Here's a fact, If I was buying a new card now it would not be a 295x2.
I've already given you alternatives that many others use.
Just because those alternatives are no good for your situation does not mean it's a fact though.
Yet others using 2 cards don't have either of those issues or they wouldn't be using them.
The 970's don't exactly run hot, are likely no louder than the 295x2 rad fan (in fact many people have to use 2 fans on the rad to stop the card from throttling) and actually will use slightly less power.
Show me an nvidia card that can beat the £530 295x2? It doesn't exist and for that price its a bargain considering its still top dog in the performance stakes dual gpu or not.
I can't afford to spend close to £1000 on a Titan X card, which is why I use AMD graphics in my computers.
Just a heads up mate, Nvidia do sell other cards that don't cost £1000![]()
Hang on there mate, let's look at the original comment shall we..
Which I replied with:
This guy isn't aware that Nvidia sell an entire range of GPU's from low to high and even enthusiast Titan X.
Now he knows AMD aren't the only option.
Which is exactly why you can't say it's a fact the 295x2 is the best option for £530.
It entirely depends on the individuals setup and without trying 970 SLI yourself you can't say it wouldn't be better for yourself either.
Adequate spacing and good case airflow is fine for blower style cards.
You honestly think that he never knew there were other nvidia options besides the £1000 option despite being on a site with a store since 2005 and links to dozens of reviews?![]()
Even aftermarket can be fine.
Plenty of crossfire 290 and 290x users on here that don't have heat or noise issues.
