There is, games will be smoother then, 144hz/144fps = ultimate gaming experience, 144hz/60fps, decent, but not as smooth in gameplay, 60hz/60fps, less smooth gameplay and more motion blur on the screen, lower image quality.
Basically frame rate is somewhat irrelevant in terms of refresh rate of the screen. Higher refresh rate means a more responsive panel capable of switching faster. At higher refresh rates, be that 60hz compared to 30 or 144 compared to 60, you get less motion blur, better image clarity. As all panels use overdrive features to accelerate pixel response time, these modes work better with smaller steps between two screens, overshoot from overdrive is usually significantly improved if not gone with high refresh screens. There has been no situation in which my 120hz panels haven't improved my overall experience compared to 60hz, browsing the web, scrolling anything, word doc, whatever else, or any and all gaming.
Even on desktop, scrolling up and down a webpage will be smoother on a 144hz panel than a 60hz panel. Higher refresh = great for image quality. Frame rate for separate and different reasons also improves the higher you go. Either is better the higher they go, frame rate is limited by refresh rate, but the reverse isn't true.
