Potential Polo Clutch Issue?
  • Thread starter Thread starter Guest
  • Start date Start date
Pretty much. Biting-point was non-existent.
This suggests a clutch problem....
Couldn't change gear with the engine turned off either.
but this suggests it's more likely a gearbox/linkage fault! It wouldn't go into any gear with the engine not running?
The pedal boxes on these Polos have a tendency to crack causing clutch issues, but you should be able to get into at least some gears with the engine not running.
