Power Consumption 8800GTX
18 Oct 2002
Mars
A follow on from a post made a few days ago,
I thought i would test the power consumption of my system
Using an Enermax 850w PSU
Testing on the wall socket
Idle uses approx 200W max
Load using various games tests, including COJ DX10 benchmark
Load never went above 300W :eek:
Maxing the CPU out in torture tests used 220w
I think that is pretty amazing considering the figures floating around
Testing was using eveything in Sig, CPU overclocked to 3.4, including 1 sata II hard drive, 4 120mm fans, and Vista 64
Im going to test my other system which has an X1900XTX just for a comparison
Something very wrong there....
An overclocked C2D is going use a lot more then 20watts from idle to full load
My own tests done here http://forums.overclockers.co.uk/showthread.php?t=17740101
My own tests of C2D at 3600ghz (with 8800gtx,3x harddrives 6x 120mm fans, 2x 92mm fans) is
idle = 218watts
both cores at full load 323watts
My tests also include a 18watt waterpump which is most likely why my idle wattage is about 18watts above yours..
Plug-in energy meter is what's it says on mine..
Or you could get a Zalman ZM-MFC2 fan controller (the top part reads out your system power consumption)
Reviewed here http://www.bcchardware.com/index.php?option=com_content&task=view&id=3518&Itemid=40
idle = 218watts
Well, i dont personally know how accurate this is,
Typing this now im idling at 198w and thats with Speedstep and C1E on the CPU
Running NucleaRus wasnt maxing out the cores , so I just tried Orthos and it peaked at 250w
Looking at your meter in your thread im using the exact same one
TAT the thing i can find that will stress the CPU enough to break 300watts...
3dmark06 , Orthos etc makes the cpu draw much less power..
Will give it ago right now, although not sure if i can get it running in Vista 64
Nah, one of the pitfalls of Vista 64 at the moment, cant get it to run even on intels own Motherboard :rolleyes:
