Power Supply for Netgear DG834
3 Feb 2003
Wirral
Does anyone have a Netgear DG834G? I have one arriving and need a power supply for it. What rating is the adaptor?
Cheers
Cheers, I am struggling to find one that would work though. Anyone know any good places (that dont sell pc parts obviously) i dont seem to be able to see any on ebay.
Just about any electrical shop should be able to sell you one. Don't worry if the one you buy is rated at > 1amp, that'll be fine as long as the voltage and polarity are correct.
Just an idea, gives you some specs to go by
slightly cheap and you get 3
yeah thanks. I just used the part number and found it cheaper elsewhere. I may actually just buy the three of them off EBay and then resell 2.
