Pre-order now! Corsair H80 and H100 Liquid CPU Coolers
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys,
The new Corsair products are now not under NDA! :)
Corsair Hydro H80 High Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3) @ £84.98 inc VAT
Corsair Hydro Series liquid CPU coolers provide a compact, easy-to-install, and maintenance free alternative to bulky, noisy air coolers, efficiently cooling and protecting your high-performance Intel® or AMD® CPU. The H80 features a double-thick radiator to maximize the surface area available for heat dissipation and dual performance matched fans. It also includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs.
The Corsair Hydro Series H80 high-performance CPU cooler fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles*.
* Requires the Corsair Link Commander, sold separately
The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool white LED display lets you know at a glance which profile is being used.
Double-up for excellent cooling
Featuring a double-thick radiator to maximize the surface area available for heat dissipation, and dual, performance matched fans, the H80 delivers cooling performance that lets your CPU keep its cool, even when pushed to the limit. And with all this cooling performance, the compact design still fits virtually any case with a 120mm fan mount.
- Corsair Link™ Digital compatibility means that you can be in complete control of your cooling.
- Push-button fan control so you can select the fan speed and cooling performance that best suits your needs.
- Double-thick 120mm radiator for increased surface area and cooling potential.
- Two all-new 120mm fans optimize static pressure and airflow for amazing performance.
- FEP tubing provides extraordinarily low coolant evaporation levels.
- A new improved micro-channel cold-plate design more efficiently transfers heat.
- Quick and easy installation brackets make it easier than ever to upgrade to watercooling.
- Includes mounting hardware compatible with all modern CPU socket designs
- Radiator Dimensions: 120mm x 38mm
- Fan Dimensions: 120mm x 25mm
- Fan Speed: Up to 2600 RPM
- Air Flow: 46 - 92 CFM
- Fan Noise: 22 -3 9bDA
Only £84.98 inc VAT.
ORDER NOW
Corsair Hydro H100 Extreme Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3) @ £94.99 inc VAT
Featuring a full 240mm radiator and two performance matched 120mm fans, the Corsair Hydro Series H100 extreme performance liquid CPU cooler is designed to deliver cooling performance that meets the needs of even the most demanding performance enthusiast. Featuring a full 240mm radiator and two performance matched 120mm fans, the Corsair Hydro Series H100 extreme performance liquid CPU cooler is designed to deliver cooling performance that meets the needs of even the most demanding performance enthusiast.
The H100 fully supports Corsair Link Digital connections, so you can be in complete control of your cooling. Monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles*. (*Requires the Corsair Link Commander, sold separately). The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool blue LED display lets you know at a glance which profile is being used.
- Dual length 240mm radiator for increased surface area and cooling potential.
- Radiation Dimensions: 120mm x 275mm x 27mm
- Air Flow per Fan: 46 - 92 CFM
- Combined Fans Noise Level: 25 - 42 dBA
Only £94.99 inc VAT.
ORDER NOW
cant wait to test one of these to see how they stack up against top end air coolers like noctua NHD14 and megahalems :)
All these new all-in-one watercooling setups makes me wana make the jump to WC...so tempting...might be time to retire my Titan Fenrir and push my i7 920 a bit more!
Might go for the h100! Looks very good but before I go for it I would like to see performance charts against top air coolers (NH-D14) and H70.
Were you short on word count? :p
Looks interesting. I wonder how they will stack up against real watercooling loops.
Given that both the air coolers you mention are cheaper and very good they have a lot to live up to! Won't be pre ordering incase they aren't very good but will be watching with interest for reviews from other companies to appear.
Wow that H100 looks up to some serious cooling. No reason it shouldn't be able to beat the top end air coolers, especially if they've put a decent pump in it.
If reviews are good, at that price point, it might actually be a real (+far cheaper) alternative to a custom water-loop...
don't tempt me to buy it if it beat my noctua D14 but the new Corsair Hydro H100 might not able to fix my Antec 1200 case ? Probably will fit two x 120mm at the rear side ! Can OCUK check this out for me please
I do like the look of the H100. interwebs suggest these are Coolit products not arsetek. The Corsair Link Commander sounds interesting too.
If it CoolIt, then it rubbish then, not sure about the pump thought as the pump is not good as custom water cooling. Corsair H50 pump is very weak I ever seen.
