Pre-order now! Corsair H80 and H100 Liquid CPU Coolers
don't tempt me to buy it if it beat my noctua D14 but the new Corsair Hydro H100 might not able to fix my Antec 1200 case ? Probably will fit two x 120mm at the rear side ! Can OCUK check this out for me please
How are they supposed to check it out for you? It's not like the products are in stock yet :)
Grab a tape measure and DIY.
The radiator is 120mm x 275mm x 27mm, add 25mm to height for the fan and some spare for the gaps.
It really isn't that hard, mate :p
If it CoolIt, then it rubbish then, not sure about the pump thought as the pump is not good as custom water cooling. Corsair H50 pump is very weak I ever seen.
LOL maybe so, but I'll wait to see some reviews before I decide. :D
Some info on the Link commander..
http://www.corsair.com/corsair-link-cooling-kit.html
Corsair said:
Corsair Link Commander is housed in extruded aluminum and mounts in a 3.5” drive bay. It connects to the cooling and lighting nodes, Corsair Link-compatible components, and temperature sensors. It communicates with your PC via a USB 2.0 header on your motherboard.
The Corsair Hydro H100 will definitly not fit in my current case, I bet a lot of people will just buy these without realising the actual dimensions and sizes of their cases - think before you decide!
Running 2 fans on really low RPM on the dual rad without the hassle of doing any plumbing is what appeals to me.
H'mm maybe time for a new case anyway.
Can ocuk please list the name and make and model of the cases here with top 2 x 120mm would be useful when all of us might get corsair H100 if it does beat the H70 and Noctua D14. I can see many are unsure if the new H100 will fit their own case.
This is looking great, fully controllable from inside the OS also, this product looks full of win tbh. Sink or swim time tho it's either gonna take off really well or flop like a biscuit in warm tea.
If your case has two 12cm fan slots together it'd fit the case, how hard is that to se lol?
yes not sure if the h100 will fit the rear 120mm x 2 on my antec 1200 case because it might block the side windows panel ?
Have you got any disability preventing you from measuring it yourself? you've got the case, you know dimensions, do you want me to get you a tape measure? I would happily do it for you but don't have any case of antec 1200 dimensions.
I dont think ocuk will respond since they dont have the cooler in question in stock yet and their resources are as limited as yours.
