Pre-order now! Corsair H80 and H100 Liquid CPU Coolers
I"ll have to mount to the front of my case on right hand side, Mountain mods twin mobo 18" square case.
will have to mod if tubes not long enough to reach socket, I do love a challenge.
All these new all-in-one watercooling setups makes me wana make the jump to WC...so tempting...might be time to retire my Titan Fenrir and push my i7 920 a bit more!
If you do I'd be interested to see how you get on, I'm on the same set up, did have it at 4.2 but flashed my board and couldn't get it above 4 afterwards :confused:
My only issue is the Antec 300 its all housed in :p Might have to take a dremel to the front and mount it front of the HDDs, that's the only way it'll fit :(
Either that or finally get a bigger and better case :p
tbh the difference from the h70 and the h80 isn't probably worth the money...just the new tech urge getting satisfied. the only really worthwhile upgrade is up to the h100
Yeah probably, even the h70 will perform very closely to the h100.- thicker vs longer Rad.
I hope the h100 tops the best air cooler :D
The Antec 1200 case is outdated now and still well too expensive! No backplate cut, poor cable management in the back and poor side panel window (that 120mm had block many high end air cooler) and the HDD bays is rather annoying with so many screws on it and had to removed the bay too.
I agree about the price but think it's down to personal preference when this case is concerned. It's just a larger version of the 902, which I own, and quite honestly can't find any faults with. Good air flow, and I'm having no problems with cable management. The only thing that I could see being a possible problem is the brackets for the side fan getting in the way of the radiator. Possibly, dont know for sure, but just going on the fact the rad on my H50 in the 902 comes very close to touching the side fan blowing on the GPU.
Someone has it.
http://www.corsair.com/blog/corsair-link-gaming-pc-build-log/
Just curious though...is there really a need for so many "improved" CPU cooler products, when the CPU architecture moving onto 32nm?
I mean take the SandyBridge CPU such as the 2500K and 2600K for example...they don't really run too hot, and since they will likely to get shorten lifespan/fried by high voltage (above 1.38 vcore), the voltage would be the limiting factor not the heat...
I still see some people doing higher than 4.6GHz on over 1.40 vcore...and I'm having serious doubt on if they CPU is gonna last, since the temp is not the issue for slowing killing the CPU...
