** Pre-Order Special Creative X7 **
7 Feb 2011
Stoke on Toast
This is due to be with me a week today so I'm going to offer it out at a reduced price of 299.99.
For anyone interested check out rids57's review of this All in one solution for your gaming and audio needs.
Creative Sound Blaster X7 External DAC and Audio Amplifier @ £299.99 inc VAT
The Sound Blaster X7 external USB DAC and audio amplifier is the ultimate audiophile upgrade for enthusiast - level gamers. Connecting easily to gaming and entertainment systems, it enhances audio quality and delivers a powerful listening experience.
Music studios have been recording in high-resolution before delivering the songs to you as CDs or digital downloads. Today's consumers are getting increasingly demanding in their desire to experience higher quality audio playback. In response, the music studios are also making such high-resolution audio tracks more accessible to discerning listeners.
The Sound Blaster X7 features a 127dB DAC capable of delivering audio tracks up to 24-bit 192kHz without any loss in fidelity. Along with top-notch, audiophile-grade components, the Sound Blaster X7 allows you to enjoy such lossless, high-resolution music the way it was recorded in the studio, whether they are stored on your PC, Mac, tablets or smart phones.
KNOCK OUT QUALITY 127dB DAC
The Sound Blaster X7 features a Burr-Brown PCM1794 127dB digital-to-analog converter (DAC) which supports high-resolution audio playback of up to 24-bit 192kHz when connected to PC/Mac, including 24-bit 88.2kHz and 24-bit 176.4kHz. Coupled with a built-in Dolby Digital decoder, the Sound Blaster X7 lets you experience cinematic true-to-life 5.1 channel playback.
In addition, the Sound Blaster features a Burr-Brown PCM4220 123dB analog-to-digital converter (ADC) which delivers high quality, low noise analog line-in audio playback and audio recording of up to 24-bit 192kHz.
TOP NOTCH AUDIOPHILE-GRADE COMPONENTS
To create the best audio experience, efforts were not spared in the selection of the finest audiophile grade components to complement our renowned in-house audiotechnologies. The Sound Blaster X7 incorporates superior class Nichicon “Fine Gold” capacitors to achieve a rich sound in the bass register and clearer highs.
And not only that, the Sound Blaster X7 is amazingly customizable — it features the option to swap op-amps. Op-amps play an essential role in amplifying the delicate analog signals and also influences the overall audio texture. Users may have their preferences for a certain tonal characteristic. With the Sound Blaster X7, you can easily swap the op-amps (available separately) to define your music's tonal characteristics to your heart's content.
KICKASS 100W STEREO AMPLIFIER
A high power, high efficiency Class-D digital amplifier TPA3116D2 delivers up to 100W power (2 x 50W @ 4?*), allowing you to connect to passive bookshelf or tower speakers. The Sound Blaster X7 features an impedance switch to select between 4? and 8? to match your speakers to deliver the best audio performance.
CLASS-LEADING HEADPHONE AMPLIFIER
To provide an outstanding headphone listening experience, a top-of-the-range Texas Instruments TPA6120A2 headphone amplifier chip is used. Capable of driving high-end 600? headphones, the Sound Blaster X7 — together with its 127dB 24-bit 192kHz DAC — delivers powerful and pristine audio.
Specifications
Audio Performance
Signal-to-Noise Ratio (DAC): 127dB
Signal-to-Noise Ratio (ADC): 123dB
24-bit Analog-to-Digital conversion of analog inputs at up to 96 kHz sample rate
24-bit Digital-to-Analog conversion of digital sources at up to 192 kHz sample rate
24-bit recording sampling rates: 44.1, 48, 88.2, 96 kHz
24-bit playback sampling rates: 44.1, 48, 88.2, 96, 176.4, 192 kHz
Stereo Direct Playback at 24-bit / 44.1, 48, 88.2, 96, 176.4, 192 kHz
Surround Playback (Dolby Digital) at 24-bit / 44.1, 48, 88.2, 96 kHz
Frequency Response
20 Hz – 90 kHz (24-bit/192kHz)
Maximum Power Output
50W + 50W (4Ω, 1kHz, 10% THD)¹
40W + 40W (4Ω, 1kHz, 10% THD)²
27W + 27W (8Ω, 1kHz, 10% THD)²
Rated Power Output
40W + 40W (4Ω, 1kHz, 1% THD)¹
38W + 38W (4Ω, 1kHz, 1% THD)²
22W + 22W (8Ω, 1kHz, 1% THD)²
Total Harmonic Distortion
0.05% (1kHz, 4Ω, 38W)¹
0.05% (1kHz, 4Ω, 30W)²
Was 329.99 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Interesting little device, DAC/ADC + Stereo Amp + Headphone Amp. Should be pretty useful, but think i'd still prefer separates myself.
