Updated with recommendations.
Excellent. Looks good.
Benchmarks between
AMD Athlon II X2 255 - 3.1GHz - 2MB L2
vs
AMD Athlon II X3 450 - 3.2GHz - 1.5MB L2
just for comparison.
motherboard out of stock, alternative - http://www.overclockers.co.uk/showproduct.php?prodid=MB-025-FC&groupid=701&catid=1903&subcat=1481
Onboard gpu will switch off with the insertion of a graphics card, mine does.
having it there wont affect anything.
having it there can be handy if you ever have a problem with a graphics card(testing) or sell the GTX460 and there is a few days gap between getting a new card.
For the price you're looking at, why bother with a dual core Athlon when you can have a i5 2300?
Why the hell are people recommending a GTX 460 OC for someone who explicitly states he doesn't want to play games?
Furthermore, why don't you, the OP, think it's a bit weird buying a high end factory overclocked graphics card considering you don't want to play games?
Sure, get a discrete card, and it's better if it's nvidia. But a 8600gs would be overkill. A GTX 460 OC is ridiculous.
edit: I may be bitten for calling a GTX460 high end, but my point remains valid.
Spending £1000 On linux PC. On a linux PC all i would spend would be £200-250 + Storage HDD
