Pro Evo 6, Vista 64, Joytech Usb ps2 to pc pad convertor, help!
16 Aug 2004
Bury
Had Pro 6 on xp for ages using a ps2 pad, (ps2 to pc usb convertor) since installing Vista 64 and Pro 6 I cant use my ps2 pad any more as I cant find any drivers or support for it.
Has anyone encountered the same prob and found any solution?
Ta,
CaNNoN
Yep, there are some Vista drivers for another adapter (made by a different company) that actually work fine for this - I had the same problem and it worked perfectly.
Only problem is, I'm not at home for a few days and can't remember the name... Email me by Sunday if I've forgotten.
