Last August during a warm spell, I noticed that one of my warning lamps had lit up on the dash. It was the far right, middle row lamp which the book describes as...
"Diagnosis* / Excess of Pollution"
This pilot light lights up when the ignition is switched on as a testing device and goes out after a few seconds.
In case of failure due to excessive pollution it will start to flash.
This stayed on for a while and after getting the AA out to look at it as I had a long drive ahead of me, it was established that the MAF sensor was faulty and needed replaced. I got this done under warranty at the time. This was fixed in September last year, just in the last week of the cars warranty.
It's back on again.
Now, the light isn't flashing, it's just staying on after the car is started just like before. Is it possible that the MAF has failed again or is there anything else that this would indicate? I was under the impression that the replacement MAF sensors had the issue fixed. What should I check? I unplugged the lead into the MAF, gave it a blow and put it back in but to no avail.
Should the MAF be faulty, would it be covered under warranty since it was replaced 7 months ago, even though the car is out of warranty?
Can anyone shed any light on this for me? Thanks
It's back on again.
