1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Problem with printer.
Discussion in 'Printers' started by Kennysevenfold, Oct 5, 2012.
  1. Kennysevenfold
    Sgarrista
    Not sure if this is the correct section, but here goes.
    Got new ink for my printer today, and replaced it.
    But the control panel for my printer says i have to buy Epson ink and not the generic stuff i have bought.
    Anyway to get around this and to get the printer working?
    Cheers guys.
  2. bignev72
    Wise Guy
    I thought it just warned you about this but then continued once you press ok?
  3. Kennysevenfold
    Sgarrista
    Yeah gave that a go with no joy :S Could i uninstall the software and the printer still work?
  4. 4T5
    Man of Honour
    Got to be worth a try deleting the Epsom software & letting Win7 chuck down a generic one.
  5. nelviss
    Hitman
    just close the ink reminder box and change the carts like normal the printer wont know the diffrence, its just a trick to make you think you need to buy inks from them.
    what modle is it?
  6. Kennysevenfold
    Sgarrista
    Thanks guys will give it a go later when i get home.
    Its a stylus dx7400.
  7. Kennysevenfold
    Sgarrista
    Seems i inserted the new cartridges wrong :o
    Supposed to do it with the printer switched on?
    anyway, works now "no ink level warning coming up"
    But!!! prints as normal, but always gives me a blank sheet out?
    No ink on it :S
  8. Baron C
    Wise Guy
    do you mean you print, 2 pages come out and 1 of them is blank?
    My experience is;
    -You must make sure to 'fan' the paper like you would a deck of cards. As paper does compress in storage and the sheets need to be loosened so that they feed individually.
    -make sure that your word processor settings are correct. As pressing enter too many times can initiate the next page.
    -check that your printer feed is free of dust and greasy build up too, as this can affect paper feed efficiency
  9. Kennysevenfold
    Sgarrista
    No no mate, i mean if i print a 1 page document from office word, 1 page comes out, but its a blank piece of paper?????
  10. unleashed
    Gangster
    You could try rebooting the printer and printing a test page. If that fails have a go at diagnostics provided with the printer software and also windows diagnostics.
  11. Baron C
    Wise Guy
    you described it better, my experience was that Word would do a mental and print a blank page.
    Its why I mentioned looking into your word processer. Google it I think there was a fix for it.
  12. horrorwood
    Wise Guy
    Sounds like you are using an old printer that you've just changed the inks on? If so its probably dried up and will never work again.
    Or maybe you have not removed the tabs off of the ink carts?
    If it is dried up you can do head cleans until it works, although it may just never unblock completely.
    This is why I now own an LED printer.
