Hi all,
Very painful moment for me. I just finished building my new PC, I went with ASRock Thaichi X399, AMD Threadripper 1950X, Seasonic Focus Plus 850W 80 Plus Gold and 4x8GB HyperX Predator DDR4 3200MHz. Got all the components from Overclockers except for the RAM. The only things I kept from my old build are my trusty GTX 670 4GB and a Kingston SSD.
I did a clean Windows 10 install and then wet on to install the official drivers from ASRock web-site for the motherboard. I only had to download and install the chipset drivers from AMD's web-site since I couldn't find those on ASRock's web-site.
My problem is that I get random freezes and stuttering when doing various things.
For instance, if I was watching a movie locally, from my hard drive, and then decided to open pretty much any program, the video and audio would freeze and my mouse would too. The audio would keep playing but just the last bit right before the problem occurs. Not sure if you get me.
The freeze/ stutter is just for a fraction of a second but still... I happens regularly and it's quite maddening. The problem is apparent also when I launch a YouTube video.
I tried running the system with only 2 of the 4 RAM modules and then changed the 2 modules with the other but that didn't help either. The stutter persists. I will test the RAM today or tomorrow just to make sure.
I also downloaded AMD Ryzen Master tools and tried switching to Creators mode. I even thought at first that the problem had gone away but then I realized it was still present.
Anybody with similar issues? Any help would be very appreciated.
Thank you.
Thank you.
