It's quite easy to take usable product shots without spending a small fortune on lots of lights or light tents etc...you just need to experiment a little
The shot below was taken using a single cheap flash unit, a scrap piece of wood that has a glossy white surface (the plasticy veneered stuff), and a couple of bits of mounting board.
(Mounting board is also known as foam core or foam board, and it can be purchased cheaply from most art shops).
I could've spent a minute or two longer in setting up the shot a bit better as there's still a hint of secondary reflection and a little shadow that could easily be addressed (just by moving the pieces of mounting board).
...but as it's just a quick shot for the MM (Members Market) it'll do
The only post processing was the removal of a few dust specks.
When shooting products especially, it's well worth familiarising yourself with the basic principle of '
the angle of incidence = the angle of reflection'...but it's worth remembering in general.
Rather than explaining it myself I've just had a quick look on youtube and found a little vid that's easy to follow:
