Project: Hush! - updated 26/12/23
OP
13 Mar 2006
OP
13 Mar 2006
Well at least no one is going to be able to steal it. How do you go about picking it up? Does it flex under its own weight? I guess it will ok once you build a proper aluminium skeleton for it.
Picking it up is okay, except without the aluminium plates the copper fins dig into the fingers a bit! It's surprisingly sturdy though - doesn't really flex as it's a big grid so pretty strong.
18 Oct 2002
Scun'orp
Are you going to leave it bare copper or are you going to spray it black? Also the port on the bottom header would that have been better on the other side, so that the tube would be inside the case so to speak?
OP
13 Mar 2006
Going to be left bare copper as I expect black paint would hinder heat tarnsfer unless ridiculously thinly coated as on pc radiator fins, in which case the paint would come off too easily.
There's two ports on the bottom, and two on the top. The ones 'inside' the case are at opposite ends to ensure equal flowthrough the tubes. The one on the very top is plugged, and used for filling, and the one on the bottom with the slightly longer port is for draining the loop and also usually plugged. :)
1 Nov 2008
Only just got the update email on this. Doh! had it on weekly updates lol.
Upgrade to pro today bandwidth exceeded, damnit was looking forward to a good update from 1 of my current favourites.
On 1 hand this is good as it means many are following this with it being awesome :), on the other you have to pay to keep the pictures up :(, this happened to me with air cube so I payed for 1 month so the pictures stayed up while there was a rush of viewers and didn't have to pay again once the rush settled down, only pay it when this happens ;).
OP
13 Mar 2006
Update time!
Lots of countersinking and tapping.
The motherboard tray will sit further back towards the back wall, but the countersunk screws poking through from the back aluminium frame just happen to be the right distance apart to go through the motherboard tray holes....
one of the 19mm anti-vandal switches (photographed badly!). It's anodised-black aluminium with white light. I'm still undecided as to whether to anodise all the aluminium black or have it mirror-polished aluminium..
Needs a bit of filing down to tidy up but getting there. :)
Not fully screwed together and epoxied into place yet so sitting on a box atm. The aluminium frame sits very snugly in the slits for the copper fins.
The copper back wall got warped from bead-blasting. Should bolt to the aluminium easily enough though.
2 Jan 2009
wow I really like that, it must have been almost impossible to get everything lined up to fit like that. Looks really good in some of those pictures, very practical too. :)
