Project: [HYDRA]™
OP
22 Mar 2019
Kiev
I was interested in the cost of the PC alone
I didn't count it...
Custom case costs me almost 3000$, watercooling 3500$+ (2x MONSTA Extreme costs almost 2000$), Ram 1100$+, CPU 1000$, SLI - 1800$ and so on, and so on...
So... over 10 000$ for sure!!! And its only PC! Without all others!
OP
22 Mar 2019
Kiev
So... I had MANY problems with this build since I posted my last log :(
It's always like that, when you building such huge progect...
There are some of problems, and how I solve them:
*I had leaks in few spots - I changed my tubes and some fittings
*Both my Lamptron FC5v2 fan controllers has been broken!!! - I repaired and modified them! They have power of 30W per chanell. But now they can work with 60W per chanell.
*The serial pump configuration in my Koolance RP452x2 top-reservoir was incorrect. It was very loud and had not enough flow rate! -
*ROG cable was too short for my connection - I modified it to 1.5m, and sleved it to black sleave. It had 16 wires!!! O_o
*EK-WB R6E Monoblock was factory broken - I returned it by warranty and recieve new!
...and other 10+ small problems.
And now I can continue my worklog. So let's do it:
*Koolance RP452x2 top-reservoir: how it was and how it is now!
*New EK Monoblock for my Rampage VI Extreme
CPU Idle temp WITHOUT fans and room temp!
*My 2x Lamptron FC5v2 fan controllers + ROG OC panel
and 1.5m black sleaved ROG cable
Additional pannel
My loop right side:
Back side:
Upper side:
Cable management:
3D grills!!!
Side tempered glass panels:
P.S:
By the way, its 5Ghz on 9900X :)
P.P.S:
meow!)))))
OP
22 Mar 2019
Kiev
Some words about 5+ghz:
I can use my i9 9900X at 5.0Ghz/1.275V and 5.1Ghz/1.335V at 24/7!!!
Also can use 5.2Ghz/1.3V but only for benchemarks (not 24/7 stable)
HT is useless) Its my opinion!
