Since I saw the new V3000 Plus case from Lian Li I've impatiently been waiting for the White edition to be available.
I immediately want to do a dual system build, and after jumping from build to build over the last 5 years I just wanted to do something a little extreme that I wouldn't want to touch for a couple of years at least.
As time has gone on, this has sort of snowballed (hence the project name and it's a white build anyway...).
My build will be as follows:
Main System:
CPU: i9 13900K
Motherboard Asus Z790 Apex
GPU: Asus RTX 4090 TUF
RAM: GSkill Trident Z5 RGB Silver 8000Mhz 48GB (2x24GB)
SSDs: 1x Samsung 990 Pro 1tB (OS), 1x WD Black SN850X 2TB (Games), 2x Samsung 980 Pro 1TB(Drives from Previous Builds), 2x Team Group T-FORCE Delta Max White RGB 1TB (Aesthetics)
ITX System:
CPU: i5 13600K
Motherboard: MSI 790i Edge Wifi
GPU: Asus RTX 4080 TUF
RAM: GSkill Trident Z5 RGB Silver 6400Mhz 64GB (3x32GB)
SSDs: 1x WD Black SN850X 1TB(OS), 1x WD Black SN850X 2TB, 2x Team Group T-FORCE Delta Max White RGB 1TB (Aesthetics)
I will be powering these with a Phanteks RevoltX 1200W Platinum Dual System PSU, and then a jumper cable to a second Phanteks Revolt SFX 750 Platinum PSU to actually power the hardware for the ITX System. This enables me to run my Aquacomputer Octo from the main PSU, and my fans/pumps etc. will run regardless of which system is powered on.
The T-Force Delta 2.5" SSD's are pretty much only there because the back side of the case is also tempered glass so I thought it'd look great having the RGB SSDs there.
I chose the 4080 and 4090 TUF GPUs because they use the same Phanteks G40 waterblocks, which greatly simplifies the water cooling loop as I will have both of them using the vertical GPU mount in the main chamber of the chassis. This frees up the room to use a full 480 radiator in the bottom.
I plan on cooling this with the recently released EK FPT Loop fans, and using the Quantum Surface radiators from EK. One 480 for the bottom chamber, one X-Flow 420 for the front and one X-Flow 360 for the top.
I'll be running dual DDC FLT reservoirs, an FLT360 on the side panel and an FLT120 on the rear fan mount.
Looking forwards to starting off this behemoth this weekend...
Main System:
CPU: i9 13900K
ITX System:
CPU: i5 13600K
