PS3, how to connect to vga?
18 Oct 2002
Bought myself a 60gig ps3 from the states ($650inc taxes), picked up a component cable aswell but i would prefer to play it through my monitor. Now i have seen a component to vga cable for under £10 but i assume this won't work?
a componenet to vga box is about £40, don't mind paying but ithe the simple £10 cable will do the job i'll get that
OP
18 Oct 2002
needs to be vga really
what i ahve seen is this box
or will just a cable like this do? (m/f may be wrong)
OP
18 Oct 2002
after reading around abit, as i thought the cable won't work its for devies that output Y/Cr/Cb of 15pin sockets. Looks like i will have to fork out for the box if i want to do it
Man of Honour
13 Jul 2004
Tony Williams said:
I heard bad stories about PS3 > VGA. Since VGA carries less bandwidth that may be a problem.
Never tired so don't quote me on that.
It's not bandwidth that's an issue. VGA does 1920*1080 easily.
27 Sep 2004
The Ledge Beyond The Edge
IIRC there is a bandwidth issue converting from HDMI to VGA in general. As HDMI also carries the Audio too, it can cause issues.
I thought one of the reasons for HDMI was for the increased bandwidth? though i may be wrong.
14 Dec 2003
Edinburgh
So when I get my PS3 I'm not going to be able to just plug it into my TFT with a HDMI -> DVI cable? are you 100% sure on that? any links etc? I can't afford to buy another monitor and I don't really want to play it through a 17" TV :(
Caporegime
11 Nov 2002
Barcelona
JUMPURS said:
Looking around it appears he may be right which i didn't know :(
Are you sure your monitor isn't HDCP??
I think only monitors with DVI or HDMI can be HDCP compatible. As it is a standard for digital video interfaces. As he only has VGA his monitor won't support it.
rp2000
Man of Honour
13 Jul 2004
Yes, for audio.
I was referring to VGA in general and not specifically for the PS3. VGA doesn't carry audio so that's a non starter anyway.
14 Dec 2003
Edinburgh
I've got a Viewsonic VX2025wm which is almost a year old, and a VP171s which is pretty ancient now. I don't think either of them are HDCP compliant, but both are DVI.
Does this mean I'm going to have to play on a rubbish TV or buy a box to convert a component signal to DVI or VGA?
