PSP PRO DUO MEMORY CARD KEEPS FLASHING
26 Mar 2010
London
I was transferring files (several gigs) over to my PSP memory card (pro duo 16gb mark 2) using the usb connection, it started of successfully but then when I came back to look I noticed the PSP screen had gone off (probably went into sleep mode) and there was an error on pc screen saying it had failed to copy the file over. So I switched the psp back on and now the memory card light just keeps flashing and won't be recognized by the psp. Tried inserting the psp with the memory card into a usb connection port but pc can't detect memory card. Have not tried card alone as I do not have an adapter or another psp. Using official 6.60 firmware.
Any advice?
Thanks
