Pug Problems
Guy
Guy
5 Mar 2007
Rochdale
Hi all,
Do you know any good car forums for Pug's? Mine just stop starting and can't jump start either :(
How would I know?
When i turn the key nothing happens at all, no sound and no lights on the dash.
How would I know?
Because that sounds like a flat battery, but if that was true you would be able to jump it.
If it was an ignition problem you would be able to bump it.
If its totally dead, try tightening the screw top battery connectors, they are rubbish. Occasionally they come loose and you loose total power.
