Hi,
I'm trying to find an adaptor which will allow me to connect an Asaka Viper as the front fan on my Nzxt Phantom but i can't seem to find the correct adaptor. I'm wondering if anyone knows if one even exists?
The case has a fan controller built in, several fans around the case are connected to a central point on the top and you can control the individual case fan speeds from there. The issue is all the connections from that point are for 3pin fans and the Viper 4pin PWM fan connector won't fit in.
I've seen several adaptors but none that are 3pin female to 4pin male, anyone know of one?
I guess if not i'll just buy a fan with a 3pin connection but i'd rather not as i've got the Viper and it's a great fan.
Thanks
Thanks
