My Q6600 runs at 3.4Ghz. I look forward to seeing your results vorticalspace
Because I missed it when I tried to navigate their site. You were right.
A 69% figure (after extrapolation) of a 3.6ghz vs a stock I7 is quite worrying for q6600 fans.
lol a q6600 will be fine, cpu bottlenecking is a myth, im only got a 3ghz dual core with my gtx 460 and i notice no bottlenecking at all, runs everything maxed and smoothly.
Because you know no better go compare you're actually frame rates of games with somelike like a core i5 760 @ 3.6 - 4Ghz and it becomes very real not to mension 460GTX is main steam 580GTX needs CPU power to get the most from it.
I'm starting to think that maybe a new mobo and cpu, and then see how the gpu fares that I've currently got. I find it very good just not so when AA is applied in quite a some games. Maybe if I had a cpu clock of 3.6 then it would be fine, 3.2 is perhaps a bit borderline.
Probably your i7 at 4.4GHz has passed the CPU bottleneck point for your cards in COD:BO, and then from that point on is just graphic power, which I would assume it is normal for you to get higher frame rate in COD:BO than MOH, if the COD:BO graphic engine is not as detailed/demanding as the MOH graphic engineAs much as it is a cpu hog I was surprised to find that with my i7 at 4.4Ghz and my two overclocked gtx470's it runs at a faster framerate than Medal of Honour.
Just got 580 installed.
So far very impressed.
Suspect Q6600 is bottlenecking somewhat but not massively.
Quickly ran Vantage at 3.2GHz on stock 580.
If I increase CPU to 3.6GHZ, it adds approx 1000 points to all scores.
GPU usage is mostly 90+ and CPU is never maxing out but I need to run some more benchies.
On the face of it, a not very good Vantage score but gaming is much improved.
"Say goodbye to pop up city"![]()
