Quality 2.1 speakers
19 Dec 2002
Gilston
Looking to get some good quality 2.1 speakers for my PC, anyone have some good advice on what would be best, looking to pay up to £100?
Ageo m 2.1's or Harmon Kardon Soundsticks II both excelent speakers within your budget
I own an Ageo M 2.1 set and these are quality - for what I pay, the sound that comes out of it is amazing - the build quality is also very sturdy (Steel). Good stuff :)
M-Audio Studiofile LX4 is the best pc orientated 2.1 you can buy google for reviews. Next step would be dedicated seperates.
nobody's mentioned them yet, but i think the aego m's are about the best you'll ever find
ahuh, yep.
Alternatively try and track down a used set of Klipsch Audio ProMedia 2.1s on the bay, as they don't sell 'em over here anymore. My set were £300 new, but the sound is absolutely unrivalled, 5 years on! Awesome speakers.
It's not a headphone socket, it's another input 3.5mm socket. Basically when that's plugged in, it over writes the input from the back - useful for plugging in your iPod in e.t.c
for £100 go second hand and get a £30 amp and some £70 speakers. Then link to pc with a RCA - 3.5mm jack
The sound will blow any 2.1 pc system out the water
In my experience, and for a higher budget than £100 s/h, I have found that the reverse is true: the Aegos micturate from dizzying height over cheap separates solutions. They really are amazing little fellows :)
As I havent used (heard) the Aegoes I cannot go against them. All I can say is that I had the Megaworks 550 5.1 speakers. I bought a combridge A1 and Mission M71 speakers. I got the 71s off the bay and they wernt that expensive but in excellent condition.
For sound quality and loudness they blow the megaworks out the water. I ended up selling the megaworks to a mate for about £70.
If your wanting them for games and dvds im sure these aegos will be good but but for music check out second hand seperates first :)
m71's are lovely little speakers but they are light on bass. if it was for pure music listening id have to agree, but i expect they are for gaming also, and the m71's wouldnt do gaming justice.
i still use a set as my main front speakers btw, but never without a subwoofer:)
I used to have a pair and the Aego's sound better and go louder without distortion. (imo)
