You think Intel knows or cares how to make any sense of that whole PCI-e lane mess?
Plan of X299 was just to separate people from their moneys.
Just like in keeping desktop platform so long limited to four cores while mostly fiddling with iGPU no enthusiast uses for really anything...
And what was power consumption of that thing?
Likely competing with FX-9590 everyone laughed at.
power consumption should actually be better than ryzen
https://hothardware.com/
as we've seen countless times, at equal voltages the r7s use just about the same power as the 5960x/6900k, at 4.5ghz on all cores the 7820x only needs about 1.15v (since Intel's process is far more refined than amds) so it should actually be lower than amds.
people quote the tdp, but forget that Intel gives a 'worst case scenario' under heavy load with avx instructions being used, where as amd quote a 'light/medium load' to make their figures look better.
to be fair though, you need to compare the 10 core 7900x at 5ghz (that was shown) to the 16 core amd, as the Intel will be equal to the 16 core due to each core being 35% faster than the amd (if and that's a big if the 16 core threadripper clocks to 4ghz)
