Just got a m2. Have a Walkman and camera icon on android screen. If I delete can I put them back on and if so how? Thanks
Not a Sony user but usually clearing the launcher data would sort that.
Glad it's sorted, how do you find the M2 so far?
Liking it along. Can't tell to much difference between my m2 and my friends z2 though this is my first smartphone so I'm not use to them. Only bad thing seems to be battery life. 8 hours on from 100% this morning with quite another of browsing and I'm down to 68%. Is this normal for a smartphone?
sorry about text size above replied using the M2 and must have altered a setting.can't work outwhat
It's normal considering it's been on for 8 hours, but it could be better. Go into "Settings" -> "Accounts" and turn off any syncing services you don't need. You may need to go into the app's settings instead to do this. For the ones you do want to sync, perhaps lower it's sync rate intead.
Text size appears normal for me. You might have a browser setting which automatically resizes the text to really large. Are you using Chrome? The latest update fixes the weird text sizes.
Using Firefox. It looks.okay in chrome but the text on some posts has grown really large onfirefox
