30 Oct 2007 at 18:26 #1 The Edge The Edge Soldato Joined 18 Oct 2002 Posts 5,730 Location Birmingham Is the wire with the line on it input 1 or 2? Thanks
30 Oct 2007 at 18:28 #2 volospian volospian Soldato Joined 18 Oct 2002 Posts 4,457 Location between Blandford Street and Mars We-elll... I hope that makes sense to someone
30 Oct 2007 at 18:30 #3 The Edge The Edge Soldato OP Joined 18 Oct 2002 Posts 5,730 Location Birmingham So do i speaker cable has two wires, one solid co,our the other with a black line. Which hole on the ISO block should i plug which wire into? My diagram has RF1 and RF 2 etc.
30 Oct 2007 at 18:32 #4 Dup Dup Soldato Joined 10 Mar 2006 Posts 11,351 Location East Lancs Generally a black line means a negative feed but with car manufaturers it could be the opposite. So, with that in mind, find out which is negative/positive for each channel on the ISO block and you're sorted.
30 Oct 2007 at 18:33 #5 The Edge The Edge Soldato OP Joined 18 Oct 2002 Posts 5,730 Location Birmingham They are pioneer speakers, and it's a small terminal so i'll go with negative. Thanks
