I want 2 maybe 3 very quiet but still giving good airflow, 2 for a push pull on my h50 and 1 for the front of my case, ive not decided wether to use a fan controller yet so any suggestions would be welcomed
If you are using it on a rad like the H50 then the Scythe Gentle Typhoons have got pretty good reviews. Though would suggest a fan controller to slow it down when idle.
For PWM fans the Akasa Apaches and Enermax Clusters are supposed to be decent.
