Should have just rebranded the 290 again![]()
So you're writing off their next CPU based on nothing very much and deriding their performance in the CPU space
They've had better performance/dollar in GPUs through most of the price ranges for quite some time now barring a few brief blips so their hardware hasn't been the problem there - it's been perception/marketing.
This doesn't make AMD's 480 a bad card, simply not right for you. If you are buying in the 480's price range then this just makes you someone to jump to conclusions given it's not even out yet so there is little point discussing further as you've made your mind up already.
Let's face it at £229 for the 8GB, if it's no faster than a 970/980, it'll be a tough sell.![]()
No, it won't.. There are a lot of other factors that make it more attractive that the 970/980.. First, and most obvious, being power draw.. lower heat output, form factor etc..
RX480 is a smaller 290 with slightly improvements. Even their own AMD customers with a 3 year old 290, don't have a viable path to upgrade, even if they want to stick with AMD. It's embarrassing.
Seriously where are you getting this from. Hawaii is the 290 which is GCN 1.1. There has been Gcn 1.2/1.3 since then with improvements and now Gcn 4 for polaris. Amd have said themselves and shown in brackets that the majority of the GPU is brand new so in no way is it a shrunk 290. Stop repeating this as it's simply not true.
Ok, let's go through this, since you're going to try and act condescending here.Multiple outlets go google it. Do you really think there would be no headroom on the power draw ???? Don't you need headroom to OC, ohhhhh snap ! You can't have it both ways! Yep critical thinking is not taught hard enough in schools, I agree.
All this improvements along with a node shrink has brought us what exactly? A card that will be 20% faster for the same price you could buy the 290 years ago?
390 was practically rebadged 290. RX480 looks from performance wise to be slightly faster than 390. Man that is some major improvements we got here.
While Nvidia gives us 50% performance increase and double the VRAM going from just the last generation. Its ok we can wait for Vega in 2017....lol
wow 18 months after 970 came out and now we get a card that's got all that, what a world we live in now.![]()
So... it's not the product but the brand name. Which is exactly what I said....
The RX480 won't change that, simply due to how unimpressive is. 1060 even if it has worse performance per dollar, it will still sale more, simply because it is called Nvidia 1060 and not AMD 1060.
The 1080 isn't 50% faster than the last gen nor does it have more RAM than a TitanX or even if choosing the 980Ti it's not doubled the RAM. Oh, or did you mean in equivalent part of the lineup, so comparing with the 980? In which case you should be comparing the 480 with the 380, in which case AMD are delivering ~100% increased performance and doubled RAM. So by your own counting they're giving the end user a bigger gain. Consistency eh?...
In todays stream they used the Ludashi benchmark the the 480 graphics score was 13.9K. To put that into prospective the GTX 970 stock gets just under 16k and 980Ti Stock 24k+.
