RAID problems on 965 DS4
6 Aug 2003
Hi all,
I keep getting one of my two drives drop out of the RAID on the above board, sometimes the drive isn't seen at all, sometimes it's seen but just doesn't work and leaves the array in a dgraded state.
I've swapped out the drives for two new ones and the problem persists, running the drives through the Samsung utility says no problems either. Removing and reattaching the drive reactivates the RAID but it fails again during the rebuild. Newest BIOS is on and drivers all updated.
Is there anything else I can try before giving up? Is it likely the port on the board is foobarred?
