Raijintek Orcus Core RGB AIO CPU Water Cooling Unit - 240mm HS-02J-RT
6 Dec 2012
notts
i got one of these mid 2018 and its just siezed up..
says 2 years waarenty, am i ok to send it back as it was only a cheap one.
thank you.
OP
6 Dec 2012
notts
its just siezed up, pumps making a noise but the impellor does not turn
if undo any of the bleed or fill fitting it does not pump any water out either
