Where/how can I see what Skill Points I already received and what Holo-Plan parts I already found?
I never checked the Extras screen so that could be it, I can see the Holo-plan pieces in the Gadgets screen but not which part is which, in other words I can't see on what planets I still need to find a Holo-plan pieceFrom memory, Skill points are shown under the "Extras" screen. The Holo-plan is under the gadgets section.
Ah, I have just touched down on the Kreeli Comet so I have to wait a bit longer I guess, thanks for the info.SPOILERS!!!
Ok after you defeat the pirate boss you get a treasure locator, now on the galay map not only will it list how many gold bolts you have got on that planet and now it has a picture of a piece of the holoplan. The last piece you only get on the last planet, so i would go back and check each planet and see if you have the holoplan.
Skill Points are indeed untre the Extra's menu option but it doesn't tell me what I need to do to get the Skill Points, only those I already finished, that should be the other way around
Anyway I'll see how many I get with normal play and resist reading a FAQ a bit longer to not spoil the game.
I heard about playing the game again with harder enemies but you also get better weapons even shen they are fully upgraded and v5That was exactly my thought!!! I just end up randomly unlocking them. Don't go the FAQ route yet. When you play the game through second time (with better weapons, harder enemies etc) you will end up getting some without realising.
Ah, I see, looks like I will play through the whole game again after finishing itSecond play through you can buy better versions of the V5 weapons and then take them all the way to V10!!
Are there any specific weapons I should use to maximize the amount of bolts and raritarium?
I ask because I noticed that some weapons don't give any raritarium drops or are the drops random?
But I think that there are also weapons that don't give any raritarium drops at all, I have been using the Nano Swarmers last night to get it to v3 or higher and I did not get any raritarium from killed enemies.Certain weapons when you upgrade have more Raritum icons and some have more ammo slots etc. I recall the flamethrower weapon is a good balance off the top of my head. Will maybe fire it up and check later.
I was annoyed that I had wasted loads of bolts on crappy weapons, but having said that, second run through the game you can get multipliers if you kill people without being hit, so the number of bolts etc is really not an issue if you play the Arena modes for a say 30 minutes.
rp200
I have bought every weapon/armour so far and still have 450k in bolts left but I am only on the comet level with a few more weapons to go.
Yeah, if you go to the weapon screen for it you will see that it has no raritum upgrades in it. Annoyingly you don't know what the next upgrade is, till you buy the adjacent one to be honest.
nano swarmers were a waste of bolts for me as were . The main thing is seeing what the overall damage is. I think about 5 of the weapons have over 1000 damage which are the useful ones. I will list the crappy ones (imo) when I fire up this bad boy this evening.
rp200
I find Nano-Swarmers to have their uses, when I was doing some Arena fights I usually drop a Nano swarmer, switch to a different weapon and kill anything the smarmers don't kill.nano swarmers were a waste of bolts for me as were . The main thing is seeing what the overall damage is. I think about 5 of the weapons have over 1000 damage which are the useful ones. I will list the crappy ones (imo) when I fire up this bad boy this evening.
So if I want raritarium I have to use a weapon that drops raritarium, that is a bit annoying if there are no good weapons but I will have to check that.
You must have played the game a lotI found though i used all the weapons and maxed em all to 5. That is until I got the RYNO then the super duper RYNO-4-EVA maxed to level 10 lol then i used that lol. Now i have all the Super versions maxed to 10 apart from the blades launcher thing (as its poo lol).
