Rear brakes
24 Oct 2002
Bucks and Edinburgh
As paradigm has indicated (he drives a BMW so it doesn’t happen very often ;)), don’t over brake the rears as it makes the car unstable under braking and can be dangerous
Caporegime
26 Aug 2003
Leafy Cheshire
Not wanting to sound obvious then, but why not upgrade the rears to VXR items (including carriers if they are required for the calipers to fit), given they will be well matched to provide the right brake bias (assuming you also swap the cylinder if needed).
OP
30 Dec 2020
I was given a full set of vented discs for the hole car and just wanted to fit them I am trying to get rear callipers and carriers to fit I have 308mm vented rear discs
