Reasonable temps for an ATI 800 XT PE?
17 Feb 2006
I have just set everything up in my new Lian Li V1000 case and the monitor shows 52Dg. Is this ok or is this hot? I have a new cooler fan on the ATI to combat the crashing but it still seems high.
That temp is fine. My X800XT-PE gets up into the 80s and it still plays good. Nothing to worry about :) That temp isnt causing the crashing, maybe a driver issue?
I have an aerogate which has a senaor attached to the graphics card. I used to use the ATI tool though, moved onto Omega drivers now. Dont know if it has the option in there.
Not a driver issue as I have updated, formated and tried everything I can. Its got to be a heat problem, buit hopefully its resolved with my new Lian Li case. There was a lot of fluff in my machine when i opened it. Now had a good clean :)
