Reccomend me a Torrent Downloader
IceShock said:
huh? confused :p
Download System
This is an epic failure. There should at the very least be an option to load the .torrent file into the client of your choice, some networking setup options would help a lot as well. Since the majority of Europe is connected by ADSL, which crawls to a stop when upload becomes saturated the ability to set some speed restrictions (possibly linked by ratio to one's download speed) to prevent peoples internet connections from being completely unavailable when downloading patches through Blizzard's EFS (Epic Fail System). The ability to pick which ports to use should be available as has been stated by others in the thread. The idea to use torrents for patch delivery is very good.
http://forums.wow-europe.com/thread.html?topicId=286873316&sid=1
Yes, another uTorrent user here. I like the fact that it will auto load torrents from a given directory automatically. Which means that I can download the torrent file from any machine in my house to a shared directory and it'll queue it up.
Also like the tagging system, so I can have all my files tagged and it'll stick them into an individual folder in my downloads folder.
And the scheduler, so I can tell it when to download and at different speeds too.
:p
utorrent hides itself under, need to tick show hidden files
C:\Documents and Settings\yourname\Application Data\uTorrent
all the torrent files are their and cache
:p
And at different times so if your ISP stops you downloading torrents at busy times you can tell you U torrent to start say after to midnight and download the torrent over night like i do.
does uTorrent have plug ins? like download scheduler to set it to stop dowloads at certain times
µTorrent.
I can only download/upload between midnight and 8am, so µTorrents built in scheduler is perfect for me.
