nice and quite, good flow rate for a slower fan than the P12
Only fan specs telling anything really usefull are size, weight and RPM.
(+ starting voltage and current)
Rest has very little usefull value.
Advertised airflow is as usefull as car's top speed in free fall when dropped from airplane.
And advertised pressure can be compared to how loud noise car's engine makes with gear at neutral when car isn't going anywhere.
You surely wouldn't buy car based on such useless data, or would you?
Both specs could be better than in other fan, which still wins in real world situation:
https://martinsliquidlab.wordpress....w-specs-are-poor-measures-of-fan-performance/
And in most real world uses you also want that airflow performance compared at some actual noise level.
Meaning actual real world airflow at some speed is also pretty meaningless, because fans can make widely different level and type of noise at same RPM.
Calm and smooth noise profile without frequency spikes allows higher RPM for same "irritation level".
While bad design's noises can demand lowering speed quite lot.
And fan vibration induced noise is another noise source contributing to how fast you can run fan.
