Recommend anything other than the Akasa Venom for a cheapish cooling solution for Q6600?
2 Jan 2009
Aus
I've finally decided to OC my Q6600 G0 and have had the Akasa Venom recomended to me, he works for a competitor and does a lot of builds so knows what he is talking about and it has used it in many builds and got good results. My other though is the Megahalems but i can't justify spending that much when there are quite a few other things i need to buy.
I am pretty set on getting it but as it's the first cooler i have bought i just want to be sure, i'm sure you can all appreciate this :)
Thanks,
Flare.
Loads of coolers in this price range, never used the cooler you are intending to get but do use the fans on my Super Mega, they certainly shift a lot of air.
I say buy it & get overclocking, don't forget to post your results :)
Thanks for the replies :D
I was also thinking about the Fenrir but i'm leaning towards the Akasa.
Good to know the fans on the Akasa are good! I will post my results, don't worry :D
what are peoples opinions on the bequiet darkrock advanced cooler? ive seen a lot of people raving about their psu's, how do their cpu coolers fair up?
