Hi folks
I'm thinking about getting a wheel and pedals to have a go against some mates with reasonable setups but not sure how much use I'd get out of it therefore don't want to spend the world on it plus it's a starter, if I like it then I'll more than likely upgrade. Can you suggest a starter wheel and pedals please, was thinking maybe the thrustmaster tmx or Logitech g920 or similar but it sure what to go for.
Thanks!
Thanks!
