Recovery CDs for presario V4000 - HELP!!!!!
18 Oct 2002
Birmingham
After a years worth of trouble free use windows on my laptop has gone for a burton. Thats the good news!
The bad news is i can't find the recovery discs that came with the laptop.
Is there any way i can get replacements out of compaq?
Thanks
Compaq and other PC companies will normally be able to supply recovery media for around £25 - £50 if you give them a ring. I don't have the number to hand. If it doesn't have a built in recovery partition then it will more than likely use 2 discs, one an OEM copy of windows and the other a driver disc. Even if you don't have the driver disc, compaq and HP are quite good with getting drivers off the website, although you wont have the software that came shipped with it, ie CD Burning etc.
