Was that the tower air purifier?
I believe so - are they naff?
I always wondered why they couldn't invent some sort of static "dust attractor" that you can plug in and it draws all the dust to it. It would be great.
Anyway as you've said other than vaccuuming and dusting regularly there's no other way.![]()
Unless you have a device in your room that is constantly sweeping the room and sucking in a lot of air to suck up said dust particles in the air.
Don't know. I wondered about how effective and noisy they are.
Do you dry clothes on the radiators? Creates loads of dust, also in the winter you don't have any Windows open
Moisturise your skin?
inb4 Gay
My girlfriends does it for me, all over, including my johnson.
Still get dust.
Still get dust.
Then get a microscope and look at the millions of dust mites feasting on your dead skin. Oh and you know when you wake up and you're a little stuffy, well probably because you are allergic to the dust mite excrement
So Freefaller, when are you going to start research and development?
I will take one if it works.
its a myth that dust is mostly skin - its actually mostly bits of fibres from clothes and bedding.
