Replacement antenna for MSI B550 WiFi mb
19 Oct 2011
I just picked up a MSI B550 Gaming Wifi board, but annoyingly the WiFi/Bluetooth antenna are the kind that plug directly into the rear io. Is it possible to buy a separate antenna that I can use, and does it have to be an MSI product or will something from any other vendor work?
OP
19 Oct 2011
Don't know if it works. But my current PC has a similar set up and position under desk and WiFi if crap is all I'm thinking
