Replacement lid and screeen..possible?
should be but depending on the age/model it may not be financially viable
If it is an older/cheaper laptop then a generic panel and replacing it yourself is the way to go ( along with 2nd hand lid )
Follow up...
It turns out the whole top half of the laptop had to be replaced as they are supplied as one part. Dell initailly quoted £460 for next day replacement! This is what the whole machine cost me in the first place. So I asked if they could just supply the part and I'd do it myself? Sure, £260 delivered.....but can you fit it yourself? Yes, I'll try.... :) Hold on sir....We'll get an engineer to do it for you as a gesture of good will :)
Engineer came yesterday and fitted it.
Excellent!
