- 4 Feb 2006
- nottingham
Wonder if someone could help me with my wiper/Wash, and front wash.
Basically the front wipers till operate, but when I push/pull or use rotate the switch on the stalk the back wiper fails to work.
I have changed the 15Amp fuse, still the same... just seems dead.
1. How difficult is it to change a wiper stalk, can is a Almera and it uses the same as this primera.
See:
http://cgi.ebay.co.uk/2000-Nissan-P...ZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
2. Is there anything else that I have overlooked that could also be cuasing the problem. After a bit of googling it seems quite common for these stalks just to die!
See:
