Replacing 3 fans on Arctic Liquid freezer II 360 rev.3
22 Jul 2021
Belgrade
Hello,i have a rev.3 can i swap instead of original P12 static arctic fans with these,they have much better airflow.
Be quiet! Silent Wings 3 120mm PWM high-speed 120mm BL070
7 Blade, PWM, Static Pressure Fan, 2200rpm, 73.33CFM, 28.6dB, FDB, 4-pin
Great,i remember when i bought 6x SW3 regular not high speed and wanted to daisy chain them together 2x3 sys1 and sys2 they didnt came like my ex fans arctic f12 with a splitter,how is the situation with this one,is there is a splitter inside Rad or no
The splitter is built into the sleeve on my freezer 2 360 rad i imagine it's the same on the rev.3 version but anyway you can just simply by a spliiter cable and connect the fans directly to a 4pin pwm fan header.
https://www.overclockers.co.uk/kolink-1-3-pwm-splitter-cable-35cm-ca-05n-kk.html
Hi sorry to hijack, I have just installed the 280 version.
I wanted to split the fans and pump.
I have the fans connected via a splitter cable. But now they are showing a pwm speed, but the pump is not. So I don't know how fast the pump is running. Any ideas.
why do you want to do that other than the fans are broken?
