RGB Fans with non RGB Motherboard
13 Dec 2020
Hi Fellas, having a real bad day. I have 3 x Antec spark 120 RGB PWM fans, but the motherboard has no RGB headers. i need a cheap solution. Fan connectors are 12v 4pin, there is a spare usb on the motherboard
Thanks for reply, i was worried about the motherboard compatibility in the specifications on the akasa, i assumed these were more of an expansion to a existing RGB header. I get the manual control option.
I think the controller is the way to go, just not the £60 Coolermaster, i went non EU and found a few more options (less Yen)
You'll just want to make sure you get a hub that connects to USB, rather than it being a glorified splitter if you want motherboard control without a dedicated RGB header.
