RGB LED - Is it possible to get Orange light?
6 Mar 2008
Stoke area
Hi all,
Figured this was the best place to ask.
I'm building my brother in law a Half life themed headphone stand so order some RGB LED's from led.me.uk and what's turned up is ****
Bent pin on the connector to start with.
The 3 rows of colours on the remote don't match the colours on the LED's. Blue buttons show green, green show blue and the orange colours are shades of pink. Nothing resembling orange.
Can you get LED RGB strips that do a good orange colour and if so, can someone link some that will do the job?
Thanks
Stu
11 Sep 2013
Aquacomputer make fairly decent kit, although you will want it connected to a USB on the PC especially if you want to alter the colours/patterns.
I recommend the RGBpx Nano with external USB connector.
You'll have to get it from ther own site, as OCUK doesn't stock that one.
